I've ran an armoured underground cable out to the back of the garden.
i.e rcd to waterproof junction box, cable to other junction box feeding a
waterproof 13A socket and a waterproof switch. Which,once everything is
running, would feed the two teeny pumps (both less than 1A).
However, at the mo', if the switch is turned on (still no pumps wired yet)
it trips the rcd.
Switch turned off, everything OK.
Is it because there is nothing wired to the switch yet ?
Wiring as follows:
From junction box to switch
Live to L1
Neutral to Neutral
Earth to Common
TIA
it trips the rcd.
Wiring as follows:
Live to L1
Neutral to Neutral
Earth to Common
TIA
