Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Are you installing a gate or a door? A door will be a bad idea if it is exposed to the weather on both sides.
Anyhow, all the usual merchants and some of the sheds sell external frames. The problem with timber frames is that they wick water up from the bottom and rot. Folks have forgotten how to look after a wooden frame. They require yearly maintenance with a dollop of love and a smidgen of care.
Just the obvious disadvantage of weather influenced movement and deterioration. The construction of a door is such that it will require a finishing product to make it weathertight, which will require annual maintenance. Being subject to weather on both sides means that it will likely be a pain in the ass.
It could work with a decent fitting gap and a wee bit of TLC.
yeah that's a good point. I had wondered if there's a 'go to' type of outside door that people opt for but looks like I'll be choosing a gate and making it as weatherproof and secure as I can! Thanks for the input
