Hi there
I am trying to replace our outside light.. Having mounted it and connected the wires inside the light, I was gutted to find that the light didn't work.
I opened the switch, which is a 2 gang switch, one side switches the hall light, one side switches the outside light. Currently, the commons are linked with a spur of cable, there is a black cable and a blue cable in each side of the one switch for the hallway, and a single brown cable which leads to the outside light in the 2 way socket of the the other side of the switch.
What I am baffled by is the neutral is connected in the light, runs all the way to the switch but has then been cut where the outer casing of the cable has been stripped back inside the switch. Is the light not working because this neutral is effectively un-terminated..??
If this isn't the problem, judging by what I have said, does anyone have any ideas?
The hallway light is working as normal. As regards to the old outside light.. It was an old one that was broken anyway and has never worked since we moved into the house.
Many thanks in advance for your help
Dougie
Dougie
