Outside lights
24 Dec 2004
Blackpool
I'm currently having house re-rendered.
I have an outside light on each side of the house, both are fed from a fused connection unit on a bedroom, next to a double socket.
Trouble is they've always been a bit too high up.
World it be reasonable to fit a junction box where therlight currently comes out, then wire they light a little further down the wall?
If so guess my question is dors it need to be a special junction box to terminate he current cable as it exits the wall and do I need to run the ength of cable in conduit or is there a special external cable I should use?
Hope that makes sense and all help appreciated.
Water is the big problem any void which warms up and cools down can suck in water, but if the void is filled, even with petroleum jelly, then no void to suck water into, so cables are black to resist UV same with plastic boxes, and need a tool or key to access.
So just common sense.
You say they are fed from a fused connection unit - can you not just run new cables from the FCU to the lights?
