Couple of weeks ago made my first post about an outside socket which is damaged. I wanted to replace it (its on its own circuit 16A MCB under RCD protection in CU so believe that is all ok). I asked about the IP rating I needed and was told IP56 would be the minimum.
Now I am in posession of my socket - I blame the olympics for not having done it sooner! but just wanted to ask about the connection outside. Presently the 2.5 T&E just runs through the wall and takes a bend into the bottom of the socket mastic'ed at the hole etc both socket and wall end. I was just wondering if this is ok? Is it ok to just have T&E exposed to elements? or should some other sort of cable be used? Now that I'm about to replace it I may as well change it if this is no good or not the norm.
I also notice that this is the same on a security light I have at the front. I have no reason to doubt this but was just surprised thats all - advice welcome.
