outside stop cock
19 Dec 2010
Cheshire
In my previous post I forgot to ask about my outside stopcock in the pavement,.....its about 2ft below the surface, I tried to turn it off, but the little handle just broke, leaving just the square end on the spindle.
I,m sure if I get the right size socket adaptor onto it, I will be able to close the tap, and then do the job as previously described in the house.
Any help or advice welcome, thanks.
That sounds like a good way forward. The square socket in an extension bar may be a better fit on the valve spindle than a socket itself.
I have a selection of various sized bits of square steel tube, salvaged from old TV stands and the like over the years that occasionally come in handy.
Thanks Keego,
In your experience, does the spindle usually turn easily once u have a good grip, or should I pour some oil or wd on it for 24 hours?
It usually turns easy enough but like everything else in life you will get the odd one that's a pig. Remember when you turn any stop tap back on to open it fully & then close it down by half a turn, do that & you will always be able to operate it easy no matter how long it's left.
just get in touch with the water supplier (STW)
they will replace the stop stap but in this weather who knows when as the ground is rock hard
