oven triping
20 Jun 2011
Nottingham
hi all just changed oven over when over isconnected themostat temprature light is on even though no selection has been made when u turn tem dial slightly it gose off when u turn oven on leave it for 5 mins or so then turn it off it will trip main fuse and keeps tripping even when u turn it on have had a nosey inside no burn marks or lose wires disconected wire from selection connection light gose off this is from themostate tem setting any ideas chaps please
Ok a little confused
Have you just fitted a new oven in.
If so was it new or second hand.
hi well its a moffat mss 600b its 4 months old and secondhand and plugs straight into socket via plug with its own dedicated circuit on fuse board 32amps its replacing moffat msf610
Sounds like you've bought a turkey. What is tripping, the fuse or mcb that supplies the socket or the rcd that covers the whole/part of the consumer unit? When you turned the oven on for 5 mins did it heat up?
yup seems to heat up leave it on for 5 mins or so turn it off bang trips main rcd all electric gose off then keeps triping the fact that the temp selector light is on even though no selection is made when temp selector moved to left a little gose off but still trips when oven turned on when warm have dissconected feed wire to selector switch from thermostat light is off coonect back light comes back on im going to try tommorow a nother test to try and get furthur insite to suspicion could be themostat switch
It seems to me more like the element is failing(earth leakage) when warm, it is a common problem with ovens on rcd circuits, just try disconnecting the element & see if it still trips. You may need a new element or need to move the socket supply to the non rcd part of your consumer unit(if you have one).
