Overflow Pipe
1 Feb 2007
Hi i have a Armitage shanks Camargue close coupled toilet but it only flushes 6 litres under the new water regulations. In the fitting manual it says you can lift the height of the overflow pipe so it can take in 9 litres. But the manual isnt giving clear instructions.
Does anyone know how to do it. Any help will be greatly appreciated.
Thank You
Sure.
But don't forget if it's 6 litre pan and someone's extravagant with loo paper, you get 3 litres of poo on the floor.
Does that answer your question?!
Bearing in mind that the toilet pans are also designed to use less water (and are therefore narrower/smaller) things will inevitably get stuck to the side.
A larger flush capacity won't actually shift those lovely stripes you get round the bowl.
