- Joined
- 2 Mar 2019
- Messages
- 287
- Reaction score
- 3
- Country
Hi. I'm building single story rear kitchen extension. Just sorting the floor out.
Will leave 6 inch air gap under joists. Span is 3.7 metres. Will be Using 8x2 @ 400mm centres.
Will use ledger plate on existing house wall and wall on new extension.
1) Are m10 bolts sufficient every 400mm? Or m12? Can I use lightening bolts? (no plugs required)
2) is it best to put down a DPM before concrete?
3) do I have to be 150mm below Dpc or does that only apply to external wall?
Was thinking 50mm below dpc which gives 6 inches below joists.
4) does the dpm have to join up to the internal dpc? How will that be done.
Cheers
Cheers
