Hello All,
I've recently lifted the floorboards on my 1950's house to reveal some damp in the timbers. The damp was coming from 5 completely blocked air bricks and the raised ground level outside. Both have since been rectified and I also intend to insulate between the joists
The ground in the sub floor space (about 18 inch from bottom of joist) was covered in a thin layer of (ranging from about 2mm to 20mm) of what seems to be similar to a concrete but missing the ballast mix. This is quite soft and is broken/missing in places up to reveal the soil. If it makes any difference under the soil outside is clay
I'm now considering what to do with the ground in sub floor space. Apart from just clean it up and patch up the concrete is there anything that would be beneficial whist I'm here such as maybee...
Lay a vapour barrier?
Remove the odd existing "concrete" layer and lay a thicker more consistent concrete bed
Do both?
Do both?
