Over the past week I have started painted for the first time and decided to use good quality brushes rather than throw away cheaper ones. I have been cleaning the brushes by removing excess paint on paper, cleaning in white spirit and then cleaning with washing up liquid and hot water when I left them for anything other than overnight. In that case I left them standing in white spirit which I have since found isn't good (deforms end of brush?). I also read washing them in hot water sets paint and makes them difficult to clean. I noticed cleaning brushes like this tends to leave the brush quite stiff (releases eventually on use) and not as soft which I assume for topcoats effects the finish.
Is there an accepted standard method of cleaning and storing paint brushes in this type of use. I know professional decorators will use brushes daily and so their usage will be slightly different but would be interested to hear if there is a "correct" way of caring for brushes?
From what I have read so far it seesms that to clean brushes for storage:
1. Pre-soak brushes in solvent e.g white spirit.
2. Don't overload brush with paint
3. Remove excess paint from brushes using paper towel.
4. Wash in a couple of washes of white spirit. (allow paint to settle out and re-use)
5. Then some people suggest washing with detergents and water, others just say dry brush off?????
I heard from a friend who paints commercial vehicles with enamel paint that they clean the brushes in appropriate solvent and then stand them in Linseed oil as it keeps the brushes supple and can be just wiped before use.
Martin
Martin
