Painting bathroom vanity cabinet.
7 Oct 2007
Yorkshire
Hello,
The missus is wanting to paint our tired old bathroom vanity unit, but both she and I are rubbish at painting and as its something we are going to look at every day want to make the best job possible.
I presume a good start is to give it a light sand to "key" the surface, but after that i'm a bit lost as for
* Whether I need to use a primer
* What paint to use for the final finish
* Do I need to sand between coats?
Cheers for any advice!
Matt
I usually (as u say) sand lightly, a scouring pad (scotchbright) is usefull as you dont want to make scoremarks that will show through the finished coat. Then a clean with a rag damped in white spirit. It seems to be melamine? or a factory laquer? So to make a good base I use this http://www.zinsser.com/product_detail.asp?ProductID=10 You can get it in small tins but is pricey.
Followed by two coats of satinwood (preferred) or your choice of paint. Satinwood don't need undercoat, stir well and thin a little with white spirit to help it flow out with no brush marks. Solvent best in bathroom.
Or. if, the existing finish is still pretty sound and you dont want a paint finish, a couple of coats of ronseal quickdrying stained satin varnish brings these up presentable.
Happy Painting :LOL:
Thanks for that, ended up getting drunk this weekend and putting it off!
But will get the stuff and have a crack at it next weekend.
Matt
