Painting laminated MDF kitchen cabinet doors
25 Dec 2013
Manchester
I have some laminated (vinyl type wrap or something) MDF kitchen cabinet doors. some of the MDF around the edges has swelled up from moisture. I intend to sand it down and use some 2 part filler to reshape what I can. I then want to paint the door but unsure what type of paint to use and the correct process to follow.
Do I simply give the doors a light sanding, apply a primer and then top coat with a topcoat. Does the top coat need to be a special finish - sating or eggshell (which is more durable)?
Need to do this on a budget but hard wearing i.e. prevent the paint from peeling off and the MDF from blowing up with moisture. What is a decent brand paint to use for primer and topcoat.
Any help or advise appreciated.
I stuck my vinyl down with clear polymer grab and a few weights until dry.
Superglue cause vinyl to melt so don't use.
Re question.
320grade sand and bullseye 123 will prime doors but allow 7 days to cure as data sheet advises. Then zinsser allcoat.
With good preparation you could just use Zinsser allcoat and skip the primer.
You could also use one of the kitchen cupboard paints DIY sell although I've never used them. They say that will go on fine
Re question.
I've got some bulleye 123 so thats handy. Which zinnser allcoat - oil based or water, interior or exterior? I've got some zinsser allcoat water based exterior?
Water based allcoat can be used inside. Think it says on data sheet
