Painting Coving Which May Have Been Painted with Gloss Before
16 Oct 2009
Derbyshire
Hi all,
We want to give our rooms a quick refresh as we plan to stay here for a few years but one thing I have noticed is I am not sure if the coving has been painted with gloss by the last owner. To me it has a shiny finish but I cant tell if that's silk or gloss
Should I just rub down the coving to key the surface and then apply some kind of undercoat so that I can paint it with emulsion when I do the celling and walls after or is there another method.
Chris
Rub down lightly and give it a coat of Zinsser Bullseye 123 sorted!(y)
Many Thanks for that info on the primer. I will look it up on Screwfix.
What grit sandpaper would you use on the coving before applying the primer then paint.
Also off subject a little but the walls and celling have a shine to them as well so looks like vinyl silk was used before. Am I best to use vinyl silk again if I don't want any issues. The walls are perfect and only need a sand down and clean before painting I think.
Chris
May be 120 or 250 you only want to lightly key the surface, you can paint vinyl silk over silk OK, the problem often comes with matt over silk it may craze or adhere poorly.
Using a soft sheen paint (a sort of halfway house paint but not that common these days) or Zinsser 123 as a primer is the way to go, if you want to use matt.
Think I will vinyl silk the celling white and prime and vinyl silk on coving white then paint walls silk as they already have silk on celling and walls so will make life easier
