P
peaps
Use a contract matt with no vinyl content to prime the plaster. Normally a 70% paint 30% water mixture. The fact that the emulsion has no vinyl means that the plaster will be breathable.
Still don't advise on painting this quickly but this will be the best option!
• Gypsum plaster is vulnerable to moisture - it can have a porosity over 50 per cent by volume. It is not suitable for external applications or internal applications where dampness occurs.
The whole idea is to seal the plaster if it's gypsum based, if you apply anything breathable your walls become damp from internal moisture.....
over time if you don't seal the plaster the walls hold a higher moisture content.
Even when you use a plaster primer paint you have to then seal it with emulsion paint.
Lime plaster does need to have a breathable paint on it however.
