    Dismiss Notice
Painting old plastered walls
Discussion in 'Decorating and Painting' started by Ljjt, 11 Jan 2019.
  1. Ljjt
    Ljjt
    28 Mar 2016
    17
    Thanks Received:
    Country:
    Hi
    I’ve just stripped a room back to the plaster finish. I have sugar soaped and filled in cracks etc so getting close to painting. Do I treat old plastered walls same as new in that apply a mist coat first or not? Also a small area has a bit of damp from an issue since resolved so I thought best to use damp seal paint on that area first, so would I apply that first, then a mist coat (if required) or mist coat first then damp seal on top? Any advice much appreciated
  2. Sponsored Links
  3. cwhaley
    cwhaley
    10 Jan 2017
    858
    Thanks Received:
    77
    Erewash, Derbys.
    Country:
    If the cause of the damp is now resolved, it would be better to let it dry out first before sealing and painting. Not doing so would surely trap the moisture in the wall and damage the finish you're hoping for when painting over.
    As for the approach to painting the wall, old plaster doesn't need a mist coat if it has already been painted in the past.The old paint would have been absorbed into the plaster making it much less absorbent. How large are the filled areas? It might be worth testing on a small area with the emulsion first.
  4. Ljjt
    Ljjt
    28 Mar 2016
    17
    Thanks Received:
    Country:
    Hi
    Thanks for your advice, the walls haven’t been painted before they where wall papered. The damp area has dried out now. Thanks
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
