painting on bare plasterboard
29 Nov 2008
Probably been asked a thousand times, so my apologies for being a lazy bstard !!!!! I have searched.....honestly.
I have just dry lined my kitchen, using paper joints and easy fill. Can I paint directly onto the plasterboards/filler, or do I need to PVA it all first.
Muchos gracias.
You can emulsion straight onto the boards.
The 'experts' will enlighten you further, but i've done it with no hiccups or problems afterwards.
Probably a bit late now but yes you can apply directly to the plasterboard.
The best way is to give the a wash coat to seal as it will be very porous.
This means water your first coat down to around 50/50 paint water mix. This will save you time and money as the second coat (70/30) will apply very easy and you will use less paint in the long run.
It will also give you a better finish as a thick first coat will show brush marks as the moisture is pulled to quickly from the paint.
HTH
