Painting Over Damp Wall/Plaster
6 Mar 2009
I need to paint an internal wall which has had a broken gutter leaking onto it externally for a long time. It has been partially re-skimmed and the new plaster is still damp; the existing plaster is also showing damp coming through where I've given it a fresh coat of emulsion.
I know the wall will take a long time to dry out completely now the gutter has been fixed, but could anyone recommend a damp-proof paint which will allow me to make it look presentable now?
The reality of your question is no, contract emulsions are in a way formulated to allow damp plaster to continue to both breathe and continue to dry after applied. Yet I dont think that they would be applicable in your situation.
Sorry but you should allow the plaster to become dry before you attempt a repaint.
Dec.
Run a rehumidifier in the room, and keep the room warm - once its thoroughly dried only then paint the wall.
You can't re-paint until the plaster has thoroughly dried out. If you try it will only delay drying time even more, the paint will eventually blister & fall off & will have all sorts of crud growing behind it.
I've had a big heater against it for most of the day, it is drying but is very patchy. I'll keep on trying to dry it out before I do anything.
Dry the plaster previous to apply paints otherwise patch will be formed. Heaters could not have a healthier result. It could only dry on the outside surface but not in the interior. Moisture will remain in walls resulting terrible impressions.
You may want to try Watertight from Promain.co.uk we used it on our basement walls that were constantly wet. I just cleaned the surface, wiped off the excess moisture and applied the paint. Apparently it works because its cement based unlike other paints. been on the walls for a few years now with no more damp.
