Painting Stairs
8 Jul 2006
Lancashire
Hi All,
I am currently preparing the hall, stairs & landing, we (lovely wife :wink:) has said we would like the stairs staining fairly dark. So that's what I have been preparing for !
Today, :roll: -- she has seen a picture where the treads are white / painted ?
If we go this route, would I use normal satinwood paint or would there need to be a "special paint" to withstand the footwork ?
I will be starting with bare timber if it helps ?
Many thanks for any advice.
Stoyer
Primer followed by two coats of oil-based eggshell but being white even this wont stay clean for long with all the 'traffic' !
I've just painted my bedroom floor white with Farrow & Ball floor paint. It looks great although time will tell how hard wearing it is.
Thinking of doing the stairs white too. Out of interest Stoyer, did you have to fill some gaps on the stairs and if so, what did you use? I used decorators caulk for the gaps between the floorboards but I've noticed hairline cracks in the caulk already so I might have to come up with another solution for gap filling on the stairs.
Thanks for the advice guys,
I am not a fan of decorators caulk, I have never had a long lasting job with the stuff.
Like you say Mazdaq, looks good at first, but eventually it cracks or shinks and leaves a messy job. Maybe if used thinly and left to dry fully it is ok, but I won't use it if I don't have too.
I have used a product from a local firm I use called "TecSeal" its an adhesive sealant that sets. Used for fitting dado's, skirting boards etc.. Its there own brand so its not readily available.
It sets hard but not like rock, so I don't think it will crack ? Plus its water soluble so its so easy to work with and paintable.
My stairs are open plan so there is no filling to do. But I have topped the skirtings, door frames etc with the sealant I mentioned.
How big are the gaps you mention ??
Stoyer
You could try frame sealant, fills larger gaps and is a bit more 'heavy-duty' , available in acrylic form too
:wink:
