Paper jointing tape peeling on ceiling above shower
26 Nov 2026
Hi all,
Looking for a quick sanity check on how best to fix this before I start pulling it apart.
As you can see in the photos, the paper jointing tape and paint along the ceiling edge right above my shower is coming away, likely from steam and condensation getting behind the edge.
Once I cut back the loose paper tape and strip out the old silicone:
  1. Should I bother putting new paper/mesh tape back into that ceiling/wall corner, or just seal the bare plasterboard edge with Zinsser, skim it smooth with filler, paint, and run a fresh bead of sanitary silicone?
  2. Any specific primer/paint combo you'd recommend here so it doesn't lift again?
Cheers!
If its a corner tape between wall and ceiling line there it just flat plasterboard behind what I can see in photo.
Run knife along wall and ceiling line. Pull tape out.
Fill.
I would use toupret power filler.
Fill. Give it a around an hour to set then hit it again with another mix. So easy filling over set but wet filler. Be dry next day.
Sand and paint.
You only need to tape plasterboard joints and it's unlikely you have one.
As for filler, the ready mixed dont set so you have to wait for it to dry before a second fill. Also filling over dry filler has its problems. I've never understood why people recommend ready mix products other than for specific jobs. Much better to mix your own imo for the setting and faster drying
Pulled back the peeling paper jointing tape and old silicone above my shower tiles and found a ~6mm gap between the top of the tiles and the ceiling plasterboard.I already have Zinsser Gardz and HB42 Pro Caulk. Should I seal the raw plasterboard edge with Gardz, pack the 6mm gap with Toupret powder filler (or caulk the back first), paint, and finish with sanitary silicone? Cheers!
