I have inherited (not literally) a two-pipe central heating system which has two branches starting near the boiler which then recombine into a single pair of pipes feeding several more radiators.
I suspect that an original 15mm run around the entire upstairs (with drops to radiators downstairs) was considered inadequate to also feed an extension, so a separate pair of 22mm pipes was run straight through the middle of the house into the extension. It obviously crossed the 15mm pipes and has been joined to them rather than just over/under, not quite in a "cross-roads" but not far off. A section of the original 15mm pipes to either side of the crossing-point has been replaced with 22mm.
Is this common? Normal even? Is it likely to have any downsides? How would you approach balancing? The system appears to work well, but having found horrors like 15' lengths of unsupported pipework, 22mm pipes in 15mm joist notches, 2x22mm pipes jammed through the same notch as hot and cold water pipes, floorboards unsupported on one side because the notch is too wide, and floorboards (across a busy doorway) literally just resting on the pipes, I'm worried about what other things might have been bodged.
