parliament hinges / rising butt
21 Sep 2011
I know it sounds a bit strange but does anyone know if there is a parliament hinge that operates like a rising butt hinge?
I suspect the strain would be quite heavy, but I have a workshop door that has parliament hinges because it needs to open back against the wall, but as the path rises any small piece of debris catches underneath.
Thanks,
footprints
Never heard of a Parliament hinge that also incorporates a rising action. You could cut the door to suit and replace this with a brush gasket I suppose. I've also seen a rising roller used in situations like this. Or how about replacing the full door with a pair of folding doors, presuming it's only the outmost edge that creates the problem...pinenot :)
Thanks Pinenot,
I have been toying with the idea of resetting the hinges slightly tilted and the lower one slightly forward of the upper one. Kinda trying to get my head around wether that would work or just be a total pigs ear!
providing the knuckles are in line
in other words both hinges will be angled at say 87 degrees or around 3 degrees off vertical so the pivot points line up
also you would need greater edge clearance at the greater throw
plus the door above the top hinge will kick in when open not a lot perhaps 2-5 mm so if the clearance is tight you will need to take it into account
Thanks Pinenot,
Depends on the amount of clearance you need, moving the hinge alignment is fairly normal. Obviously throwing the bottom hinge out will throw the opening corner upwards, I alway take out two/three screws of the top hinge leaving the top one, which a slacken. then I cut and glue in sharpened dowel/splinters of wood which get hammered in full depth and snapped off. I do this to stop the old screw holes pulling the hinge to it's original position...pinenot :)
Thaks guys as it is my workshop door, a very snug fit is not required so I think it is worth a go if there are no super duper hinges I can use :wink:
Regards,
footprints
Footprints
Did you resolve your problem with a finding or developing a rising parliament hinge?
CuriousBuilder
More or less, I did the thing of moving the bottom hinge out slightly which helped a bit. However we decided to replace the old concrete with brick sets and the final level was a bit better so now it clears.(y)
