I believe Part M requires the breakers in an enclosure to be mounted between 1350 and 1450mm?
I'm intending to change my incoming supply to a TP&N supply so I can use a decent size ASHP and solar.. Due to the DNO not wanting the new service cable running under my garage floor in a duct, a sensible option seems to be an external meter box on the side of the garage - however I dont really want to mount the board low down and would prefer it up and out of the way and then have a sub-main to the house CU.
are there any workarounds regarding the height on other boards?
If I can get the route 'simplified' then I could do away with a submain for the house and mount the enclosure at an acceptable height within the proposed plant room.
Ta
David
Ta
David
