Partition wall in garage
1 Oct 2007
Hampshire
So. I know this comes up a lot. But I just want to clarify something.
At what point does putting things in a garage constitute a 'change of use'?
Is it when I put a sink in?
Is it when I put a washing machine in?
Is it when I put a stud wall cupboard in?
Is it when that cupboard takes up one end of the garage?
Is it when I put said washing machine and sink in that cupboard?
Basically, I don't care about heating the place. I just want a closed off area for the washing machine and a 'dirty' sink so they won't get covered in metal shavings from the work shop. And for the addition of a £100 stud wall, I don't see why I should have to pay £££'s more for building control issues :/
There is no law against putting a sink, washing machine, cupboards etc in a garage - it's not a material change of use.
Change of use is a planning concept and does not apply for using a garage for another purpose.
In terms of using the garage, it no longer becomes a garage when you start to use it for purposes more akin to what would be done in a different room. Put in your sink and washing machine and partition it, is more like a utility room for instance. And such a partitioned space presents a higher likelyhood of producing condensation issues which could affect the building - so needs to be controlled via building regulations.
Quite right - I was thinking of 'material alteration'.
But if I were the OP, I'd just do it; who would know?
Well, if the only issue is condensation (from a practical concern stand point) then I'll leave a decent vent gap at the top of the wall to provide ventilation. Worst case, if I come to sell it, I undo some wall bolts and remove the wall :)
There's plenty of evidence to what happens when a *bad* conversion is done left over from the previous owners illegal room modification.
It's a garage, get it done - put a vent in etc - just do it.
No one cares about council involvement for something like this as long as it's easy enough to knock it all down later.
Do they? Does anyone actually tell their house insurers about any and every modification to their house?
Do I have to let them know when I wallpaper the lounge? Or are we talking structural modifications? (of which a partition wall is not one). :)
If you alter a room to form another use or an additional room, you alter the risk. If you carry out works without authorisation when authorisation would be required, you breach your contract of insurance. It does not matter if a wall is structural or not, but little things like fire resistance might.
Obviously, none of this matters until you come to make a claim.
What a lot of people forget, particularly in the Summer, is that these poorly insulated/ventilated spaces become almost unusable in the winter.
Do it right - do it once.
