- Joined
- 25 Apr 2017
- Messages
- 5
- Reaction score
- 0
- Country
Hi All,
I have been doing a lot of work on a terraced house build in the 80s and unfortunately the building standards are rather poor. I am planning to tackle the party wall insulation next which is pretty poor overall.
On inspection, dot and bad has been used straight onto breeze blocks to stick plasterboards and the plasterboards were then lined with paper... So insulation / accoustic or thermal is pretty limited (to stay polite).
This is already a very narrow property so ideally I would like to minimize the amount of space lost. I have been reading and looking around and was wondering what would be the best way to deal with this.
Without touching the existing plasterboards I probably have about 40mm to work with. Is it possible to implement something reasonable with that amount of space? Would adding another layer of (accoustic) plasterboard and plastering on top make any difference? Would fitting resilient bar and filling the gap with insulation (mat/foam/whool?) and fitting plasterboard to the bars improve things as well.
Removing the existing plasterboard and battening the wall altogether and installing the relevant cavity insulation etc... could also be another option.
I'd appreciate any thoughts or advice on the above.
Many thanks in advance,
Guillaume
Guillaume
