passing 40mm pipe through wall - use 50mm core drill
11 Apr 2006
Berkshire
When coring our a hole in an external wall for a 40mm waste pipe, would you use a 50mm core bit so that you could use 5mm of sealant all round?
£1 to a pinch of s*** says your nominal 40mm pipe isn't actually 40mm OD.
and a chance to win your money back - another £1 says the hole won't finish dead on 50mm either.
If the hole isn't looking dead square at the pipe run you'll be glad of a bit of clearance anyway.
Normally you would use a 44mm but 50 is fine as said previously, as long as it IS actually bigger, is doesn't really matter, just a little bit more making good to do really mate.
Cheers guys, I was thinking that a 40mm hole would be too small because that would leave zero space to get sealant in. I didn't realise you could get 44's... I'll go buy one.
