passing cables through layers of insulation (help please)
Until you hit a joist/noggin.
Call me mr negative, but it's not easy even fishing across a ceiling that has no filler in it!
OP has said it's only 1.2m. between each hole.
C'mon. Let's be more positive.
Don't talk to me about positive.
Correction - it's 1.25m. - It'll be impossible.
I was in aldi the other day and they had a set of wiring rods for less than a tenner
OK...
Progress (partially). I manage to connect 2 of the three holes with cables. i used a drain rodding system that I had. I am now stuck on the last one! I may try a good ole fashion steel hanger if I can get my hands on it.
Thanks for all the help.
Drill another interim hole and keep the disc that falls out, use hole to assist routing, cut a rectangle of wood: width the diameter of the hole, length 1.5x the diameter. Partly wind a screw into it centrally to use as a handle, fit wood by pushing into hole and aligning. Use wood glue to fix and leave to set, next day use screw to attach circle cutout. Fill edges with some filler, sand and paint
Also, Aldi had inspection cameras the other day.. Kinda like a camera on a bendy rod, hand held screen. No idea on quality, but may suffice. I've also set the iPhone on video mode, enabled e light and pushed the camera part into the ceiling hole before now, keeping the body of the phone in the room to look at the screen. It's helped, if only to confirm I've completely missed putting a wire in. Yes, insulation filler makes the job a bit harder, but you might be able to poke it out of the way...
I have a Ring video borescope and it is very handy (Costco) although mine doesn't record as some do
Aldi offer a money back guarantee
