- Joined
- 11 Sep 2022
- Messages
- 4
- Reaction score
- 0
- Country
Hi, this is my first post, I hope the below will make sense. We have been doing some research online but still in a bit of a quandary about what to do!
We have had a small new extension put in with bifold doors in place however the foundations and new DPC are below the patio. Unfortunately the patio slopes slightly towards the house, and so does the foundation, meaning we have seen water running under the dpc in the recent down pours we've had. This is also exacerbated by the fact that there are two different levels of foundation and the base of steel post interfering (see photos).
One solution would be to lower the ground outside below DPC and perhaps install an aco drain? This would likely mean chasing out some of the concrete foundations, something we're concerned may compromise the steel.. the main piece of concrete that the steel post is bolted to is 1mx1mx1m. This would still leave the foundations higher than the patio so we have thought about adding a full length step to cover this.
Essentially we'd like to find the easiest and best looking solution if possible but struggling as to what this could be.
Any advice would be greatly appreciated.
