Patio Issue - Concrete not set and swelled
Use a wetter ( i.e. less dry mix) for the mortar, from what you say the sub base isn't a problem with the rest of the patio.
Let us know how you get on.
Blup
The flags on your patio are not butt jointed, you can clearly see gaps,was this done to help drainage? they will move/slide, but if flags are pushing up the problem will be the sub base too.
The flags were butt jointed until they all started moving. I cant understand it being the sub base when where 3 flags were relaid that are part of the original path at the same time as the new patio, these 3 flags have lifted too but the original path is fine/same sub base, its like base has swelled. On the new patio where the hot tub was, this is now down and the base under it is completely flat too.
