Hi folks,
We live in the south of France and would like to pave an area of our garden using pavers (large format ones, say 50cm x 50cm). We want to pave a total area of 40m2 (~400 sq ft).
From what I read, I need a weed barrier, then gravel foundation of around 10 cm (4"), then sand and then the pavers. Some people seem to use mortar - do I need to use mortar for the pavers? Here is a link to the type of product I am considering (they are 50mm thick):
https://www.leroymerlin.fr/v3/p/pro...e-ton-pierre-l-50-x-l-50-cm-x-ep-50-mm-e30361
Also, within the area I want to pave, there is an existing paved area (concrete with tiles on top) of 8m2 (80 sq ft) and a separate concrete slab (very not level) of 10m2 (100 sq ft).
I'm not sure how to work around this and I'm wondering if anyone has any creative suggestions? If I put the pavers on top of the existing tiled terrace, I will be too close to the door threshold in height (how much lower should I be?)
Other than digging up the terrace or pouring concrete over the entire area and using a thinner tile on top, are there any other ways around this problem?
I am assuming pour concrete and tiling on top is going to be way more expensive since I won't be able to do it myself?
Thoughts?
Edit, another idea is to find a tile with the same finish as the pavers and use the tile over the existing concrete base areas - this will solve the height problem, but will it be difficult to get a level homogeneous area where there are two different foundations?
Thoughts?
