    Dismiss Notice
Peeling wallpaper and cracked ceiling.
Discussion in 'Plastering and Rendering' started by Scud14, 21 Jan 2012.
  1. Scud14
    Scud14
    18 Apr 2010
    53
    Thanks Received:
    2
    London
    Country:
    Hello guys... when i moved to the house, it was nice and ok, but after months i started noticing some cracks in the ceiling.
    There is a crack in the ceiling above the stairs. Above that ceiling is the loft, where there is old insulation material and wool like stuff. the crack is shaped as if there is a wood bar above it... i mean like sstraightline from the wall on the right to the left.
    There is another issue with the wallpaper. The living room wallpaper starting to peel away, as if the are dry.
    in the bathroom ceiling i noticed the ceiling paper if i may call it, is peeling as well.
    what are the causes for the issue above? and how can i fix them?
    many thanks
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    Cracks in ceiling often occur with movement or water damage on joist joints.
    Do you know what surface material the plaster is laid on? ie plasterboard or lath.
    You will need to investigate further options are:
    1) secure surface, tape joint cracks then further options are fill out or blend in plaster or over skim whole ceiling
    2) overboard and skim
    3) rip the lot out and start again
    Wallpaper on bathroom ceiling, not a good environment for wallpaper. Condensation likely cause.
    Resolving issues would involve in removing wallpaper and have painted ceiling.
    Reduce condensation, open window, time delay fan, good insulation and vapour check ceiling, lag any exposed pipe work.
    • Thanks Thanks x 1
  4. Scud14
    Scud14
    18 Apr 2010
    53
    Thanks Received:
    2
    London
    Country:
    Thanks a lot mate.... I'm not professional so I had some difficulties understanding some names but I'm sure your reply would help any builder or experience man to do the job.
    But thank you :)
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
