    Dismiss Notice
Permitted Development rights for L-shape side extension
Discussion in 'Building Regulations and Planning Permission' started by Ian1986, 5 Feb 2020.
  1. Ian1986
    Ian1986
    5 Feb 2020
    4
    Thanks Received:
    Country:
    Hi first time poster on here. I am a structural engineer by trade but now and again get asked how big can i build my extension and sometimes the Permitted Development guidlines online just don't clarify certain things...
    looking to build a side extension to an existing bungalow (not designated area) but the side extension is 'L-shaped' in order to prevent loss of light to two existing windows.
    i understand width of new extension must be half the width of the main bungalow, the eaves height cannot be any higher than the existing (and less than 3m), the maximum height is 4m, 2m from the boundary,
    therefore i believe the extension would 100% be PD if the extension was closed off rather than L-shaped. does the shape complicate the PD rights in anyway or is the worry over nothing?
    any thoughts would be greatly appreciated.
    Ian
  2. tony1851
    tony1851
    23 Feb 2012
    9,436
    Thanks Received:
    1,411
    Manchester
    Country:
    That's P.D., no doubt; the cut out makes no difference.
  3. Ian1986
    Ian1986
    5 Feb 2020
    4
    Thanks Received:
    Country:
    thank you tony for your answer. much appreciated. Ian
  4. jonbey
    jonbey
    17 May 2012
    4,221
    Thanks Received:
    239
    Country:
    Or is it? What was the footprint of the house when first built. I thought that if that extension is beyond the original rear boundary (or boundary at some time over 50 years ago (can't remember the date)) then it would be considered a side and rear extension happening at the same time, and the width would possibly exceed the PD rules.
    But I might have (probably) misunderstood it !
    For something like that I'd probably put in full planning, just to be safe. If you paid for those plans then the cost of planning isn't going to add much and you'll never have nosy neighbours raising concerns later on.
  5. Sponsored Links
  6. tony1851
    tony1851
    23 Feb 2012
    9,436
    Thanks Received:
    1,411
    Manchester
    Country:
    You have a point; AFAIK, OP described it as a side extension, but is it? If the original entrance is at the top of the plan, then yes, it's a side extension. But if the entrance is the doorway on the right (?) that makes it different.
  7. Ian1986
    Ian1986
    5 Feb 2020
    4
    Thanks Received:
    Country:
    it is 100% a side extension. the previous architect tried to claim the extension was a rear extension due to the location of the front door (and then tried to go for the extra large rear extension application). needless to say he was put right by the planning department. the front door does not make it the principal elevation.
  8. Ian1986
    Ian1986
    5 Feb 2020
    4
    Thanks Received:
    Country:
    the footprint of the original bungalow was everything you see in the drawing with the exception of the rear addition named playroom. Ian
  9. tony1851
    tony1851
    23 Feb 2012
    9,436
    Thanks Received:
    1,411
    Manchester
    Country:
    If the LPA have determined that the previous (failed) application would not be a 'rear' extension, then their implication would have to be that yours is in fact a side extension, so you're in the clear.
    Thanks for clarifying.
Loading...
Share This Page
