Phosphorus/Posphates in a concrete floor
15 Aug 2011
West Midlands
Am selling a 1960's house, and the buyers surveyor wants to take a second look as he thinks excess phophorus/posphates in the floors may be causing cracks in the walls. Has anyone come across this before and is it a major problem?
It's sulphates, and specifically "sulphate attack" of the concrete, not phosphates
I've explained it previously on here, so if you search you should find an in-depth explanation
With regards to your surveyors concerns and sulphates, it is unusual for cracking in the walls to be present without significant [visible] problems with the floor too
Cracks in the walls related to this problem would be confined to the walls below ground or some bulging at floor level - but normal vertical or stepped cracking higher up the walls would have a different cause
