Pilot problem Britony II T Water Heater
29 Jan 2007
Essex
Hi Guys,
I am having problem with my Britony II T water heater. The Pilot went off so i turned it back on like in the book but as soon as I turn the dial past the mid point it goes off again. If I leave the dial half way the pilot stays on but that does not help as heater fire doesn't come on when hot water tap is opened.
Any ideas :?:
Is the mains on?
If so, next most likely is thermocouple but there are other things.
Is it a model with a fan?
:arrow: Mains Gas is on
:arrow: Water is on
:arrow: Pilot does come on (but goes off once dial is twisted past mid point)
:arrow: This model does not have any fans (plain simple design with flue)
Thermocouple reqd but can be quite tricky 7mm box spanner or a 7mm socket to release nut under pilot burner
OK great. thanks for your help
Get yourself a new spark electrode too, always eroded thin and you knock the end off...
