Pipe dripping under sink feeding tap - can I fix? with pic
13 Feb 2009
Denbighshire
it's the pipe that feed the hot water tap. Dripping steadily.
It is where the t-junction is. Can I easily fix this myself? Money is tight and I want to avoid calling a plumber if possible.
thanks,
Steven
PS please note pic is rotated 90 degrees
Your best bet, cut the pipe just below the leaking fitting. Buy speedfit/pushfit Tee-Junction and simply push the pipework into it, This is a more permanent fit.
Of you could try LSX leak seal, although this will cost you a tenner or so, whereas a pushfit fitting will cost you £3. Or you could call me out and i'll do it for you for £20 :)
if you do don't forget to clean the paint off the pipes :idea:
silly q but how do you get the paint of the pipes? I've tried using a blow torch in the past with no luck.
Thanks for all replies folks.
Fortunately, and old friend who is a plumber took care of it for me.
cheers
gubar
