Pipe Freezing Kits?
8 Dec 2010
Hi
I want to change a sink over - there is no isolator valve on the pipes. I'm worried about turning the water off because I am scared of getting an airlock.
Would a pipe freezing kit be a good idea? Any recommendations?
Many thanks
Turn the water off. The chances of an airlock are far lower than the chances of a flood if the ice defrosts before you're ready for it
OK. I will avoid the kit and turn the water off.
If I get an airlock after I've turned the water back on, how do I clear it?
Hand over the tap, turn the hot on first then the cold, wait a minute or so, turn cold off then remove hand. With a bit of luck you'll clear the airlock and won't get too wet
