pipe freezing
want to take out pipes from my central heating system. cant be bothered draining down , refilling then airlocks etc etc.pipe freezing seems the far easier solution. just afraid it may burst pipe or something
unless the system is massive or you've had very bad problems previously drain down. only freeze if you know exactly what you are doing.
I was going to ask what type of system it is but i dont care if you cant be bothered draining down, try it, but who is going to clean the carpets etc when it goes wrong
why bother freezing it? just cut the pipes and "snatch it" its much quicker,
and saves on cost, you just get a bit wet and have to clean up after
I wish you luck
