Use Hep2o instead of Speedfit.Any ideas?
Note that one of the functions of the insert is to ease the O ring over the otherwise blunt end of the pipe - pushing the pipe in without the sleeve on risks damaging the O ring.Alternatively, just leave them in.
The pipe will still push over them when reconnecting.
get some gash pipe. chamfer then smooth the outside circumference of the pipe, then cut off ~12mm of pipe.
Push your short length of pipe into fitting, over the insert, using spare pipe to push it home over insert and thru O-ring
Withdraw spare pipe, compress collet, grasp protruding end of insert with longnose and it should come out easily without knackering O-ring
Nick
Nick
Why !!!!!!!!! just unscrew the nut and take the insert out
