pipe knocking
29 Dec 2020
I realise there are threads around this, but I haven't found the symptom I have, so maybe someone will be able to point me in the right direction.
After the central heating has been on for a while a loud rapid fire knocking starts. It stops the instant I turn the tap on (have been turning hot water tap on and don't know if it would also work if I turned cold water tap on).
I let the tap run for a bit, then turn it off. Sooner or later the loud noise starts again and I have to repeat the process.
The only way to stop it for good is to turn off the central heating (combi boiler).
I thought it might be an air lock. I bled all the radiators this morning but no air came out.
Any suggestions?
CBW
26 Sep 2019
North
Sounds like a failing float valve in the feed and expansion cistern, unless you have a sealed system/Combi boiler?
29 Dec 2020
It's a combi boiler. I can have the central heating on for
hours with no noise, but then it will start. I thought it might be heat related. I don't have a thermostat in the house, although the temperature on the boiler is not set very high.
CBW
26 Sep 2019
North
Does the pressure rise at all, or do you lose pressure frequently? What make/model of boiler?
29 Dec 2020
I haven't been keeping tabs on it. I have just had a look and the pressure is 1.5, dead in the middle of the green.
It's a Worcester heatslave 2.
Ive got the hot water on now and there is no noise. I will leave it on to see if a noise starts up without the central heating being turned on.
  • Thanks
Reactions: CBW
