Pipe layout in bathroom - advice please!
9 May 2007
Oxford
ok guys, following on from a recent thread about my current home renovation (bathroom) project I wanted to get some advice on laying the pipes safely.
I need to cross the room and was going to n otch the joists (3 of them) in order to get the 2 pipes across to where I need them to be..
It is a sturdy floor and 6 or 8 x 2 joists (havent checked but they are solid)
The notch would be a pipe depth (no surprise there) and the location is at one end of the room where the joists meet the wall (about 1 foot away)
So, is this acceptable? (as lots of houses have it!)
Also, the final goes down the length of the room (running the direction of the joists)... what is the best way of securing the pipes or routing them when they are between joists (eg/ running parallel with them) please?
I dont want pipe hammering etc when I get this poject done!!
Lastly, regarding notches, Im sure Ive seen metal pipe protectors for this exact purpose... but I cant find any on the web?
ANy ideas please
thanks
24 Jul 2003
London
You can notch at a position between 7 and 25% of the distance ftom a support to the next one, and go up to 1/8th of the depth of the joist.
Both are widely flaunted, sometimes, eg if the supports are a foot apart, because the rule is sometimes daft.
You can drill through joist centes too, I'd have to check the positions.
Put a 2 x 1 batten between joists for support. Cut it sligtly long then tap it into place ie jammed at a slight angle. Then screw it don't nail it or you might crack the plaster. Screw a pipe clip to it.
16 Dec 2006
London
Protectors are for use with electrical cables but would do the job and are available from electrical wholesalers and on the web
9 May 2007
Oxford
Thanks Chris.
Thats exactly waht I was looking for mate :)
I think i will go with the notching then as drilling holes through joist centres will be much more awkward. (and I havent got a right angled drill like the Dewalts that are sold)
Do I need to to secure the pipes that are in the notches? The pipe clips will be higher than the floorboard bottoms if I did, so I would probably have to mess about chiselling hollows in the bottom of the boards?
14 Mar 2009
Manchester
Mostly right apart from notches should be between 25% and 40% from a supporting wall. :confused:
9 May 2007
Oxford
Well that doesnt make any sense.
Surely the joist will be weaker the nearer to its centre section you go??!!!!
