    Dismiss Notice
Pipe size for unvented system
Discussion in 'Plumbing and Central Heating' started by BuildingNovice, 30 Jul 2010.
  1. BuildingNovice
    BuildingNovice
    3 Mar 2010
    90
    Thanks Received:
    Aberdeen
    Country:
    We have an unvented cylinder with system boiler setup, and are finding that water flow in shower falls as basin taps are opened, which I understand should not be happening with a 'megaflow' type system.
    I've been told that one option to improve the water flow is to increase the pipe size coming into the property.
    My question is would this increased size need to go all the way to the cylinder (which would be a major job) or could it just be to the stopcock (which is more feasible) although then have you not just shifted the bottleneck location further up.
    Any advice appreciated.
  2. Sponsored Links
  3. Agile
    Agile
    26 Jun 2004
    64,017
    Thanks Received:
    4,591
    London
    Country:
    It all depends on where the main restriction is located.
    Thats usually in the pipe from the street to the house.
    Its normal to distribute up to the cylinder in 22 mm.
    It needs to have the input pressure at the cylinder measured and a graph drawn of pressure against flow rate.
    I assume this has always been the case since installation and that it has been regularly serviced.
    Tony
  4. BuildingNovice
    BuildingNovice
    3 Mar 2010
    90
    Thanks Received:
    Aberdeen
    Country:
    Thanks - I'll measure the pipes and report back
  5. Agile
    Agile
    26 Jun 2004
    64,017
    Thanks Received:
    4,591
    London
    Country:
    Its not the pipe sizes which are most important but the resistance as demonstrated by loss of pressure at the inlet as flow is taken.
    Tony
  6. BuildingNovice
    BuildingNovice
    3 Mar 2010
    90
    Thanks Received:
    Aberdeen
    Country:
    Thanks again Tony - there is a gauge next to the stopcock and near the cylinder - I will measure the readings and also the flow rate.
  7. BuildingNovice
    BuildingNovice
    3 Mar 2010
    90
    Thanks Received:
    Aberdeen
    Country:
    The mains pipe into the house is 15mm to the internal stopcock and then 20mm has been used for cylinder/boiler connections.
    The pressure gauge next to the stopcock is showing 2.5 bar (with no taps running).
    I'm not sure how to measure the water flow - presumably you put the tap on maximum?
    So, will changing the 15mm to 25mm and leaving the 20mm in place make any difference?
  8. Sponsored Links
  9. Agile
    Agile
    26 Jun 2004
    64,017
    Thanks Received:
    4,591
    London
    Country:
    You must give us the test information.
    To measure flow you time how long a bucket takes to fill and use simple maths to see how many litres per minute.
    Do it at 1/3, 2/3 and full on for a start. Measure flow rate and see the pressure on gauge at that flow rate.
    Tony
  10. Happyplumber
    Happyplumber
    9 Feb 2009
    4,237
    Thanks Received:
    1,008
    Berkshire
    Country:
    15 mm inlet from mains is not really good enough from experience ,this should have been noted by the installer and the pipework changed to the incoming mains for 25mm mdpe at least.
    This would have resolved the issue of flow ,I can see this problem continuing until the mains into the house are improved
    Sometimes a tiny drop of solder can cause major issues ,hey Tony!!!
  11. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    Chain is as strong as the weakest link. In this case that means you need to upgrade the smallest pipe first, which probably means going back to the meter/streetvalve.
  12. Agile
    Agile
    26 Jun 2004
    64,017
    Thanks Received:
    4,591
    London
    Country:
    Until he has measured the pressure/flow we just dont know. For all we know it may be a blocked filter or a swollen tap washer!
    I am doing work at a property with a 1/2 supply and it gives 47 litres per minute open pipe at the bath.
    When the owner told me that at first I asked him to measure it again and give me all the figures. But he was right!
    Tony
  13. Happyplumber
    Happyplumber
    9 Feb 2009
    4,237
    Thanks Received:
    1,008
    Berkshire
    Country:
    You carry on measuring and doing calculations Tony,let the real plumbers tell you from experience,have you cleared the blockage you created,three visits at least now from my calcualtion,poor thing from 47 down to 6 litresoh how i wish all the general public could see your post to prove you competence that is hidden in the combustion chamber!
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
