I'll start off by saying I'm not a plumber but keen DIY'er. I am in need of replacing all the Rad's in my house as they are about to burst. They all have a corroded spot at the top. At the same time I think its best to replace the pipe work incase the whole system is rusted from the inside out.
While I am going to use a plumber for the main bits of work I am considering doing a lot of grunt work myself, mainly re piping all the rads and fitting new rads.
I want to install a multi zone system - ideally each room is connected to a manifold individually and would have their own room stats. So my first question is around that. I get lots of different opinion on this.
Q1, Given the opportunity and not considering cost/effort would it not be a good idea to plum each room on its own circuit, or would it be better to just do upstairs/downstairs.
Q2, If so what pipe size should be used? Presumably on a standard ring would have a larger standard pipe then each spur is smaller.
Q3, I plan on using speed fix for under the floors but use copper where visible. Is this sensible?
Thanks for any help.
