pipe stat problem
5 Feb 2012
i was wondering does anyone know which way is best to wire a pipe stat to a stanley solid fuel stove,stanley recommend that you fit it on the flow.here,s my problem,i have the stat on the flow and its wired so as when the pipe reaches 60 degrees the pump comes on,however whenever the pipe cools it doesn,t turn off the pump.the stat has 3 connections on it, number 1 is common,2 is outlet opens the circuit with increasing temp,3 is outlet closes with increasing temp.i have my live from my spur switch going into common and then my pump live is connected to number 2,terminal 3 is not used. does anyone know if that is wired right and if it is why is the pump not turning off
You've got the Woodwarm installation details, it was on a link on a post from your last thread. That's got the wiring details of a High/Low pipe thermostats.
HTH
Terminal 3 is mor (make on rise) So you've wired it wrong.
But as said refer to the woodwarm diagram for Hi/Lo pipe stats or instruct someone to wire it correctly.
