I'm getting new carpets laid down next month - and want to fix one particular radiator first.
At the locksheild value (water exit) of this radiator, the coupling is leaking and has rusty water drips down on the pipe. I've disconnected the radiator from the wall and will soon flush all radiators AND use a Central Heating System's cleaning solution, thence a Anti-Corrision liquid at the end.
However the screw threads of this coupling's female nut has rusted. Its affixed to the pipe with a 'kink' at the top of the pipe to stop the nut from coming off. In other words, I can't get this nut off to clean the threads OR to replace it.
Is there a way I can clean it easily? Any quick-remove rust solution to brush it into the nut? Or is it a job for the plumber to cut & replace the coupling?
hope you could help.
- Andrew
- Andrew
