- Joined
- 13 Dec 2007
- Messages
- 4,008
- Reaction score
- 662
- Country
Generally speaking, a combi requires a lot more gas to heat the domestic hot water than it does to heat your house.. an average small to medium sized house can be heated with a 12Kw boiler.. to get a decent flow of water from a combi you would need upward of 24Kw, though even 24Kw is regarded as a bit limp wristed these days and a 30 Kw is usually the preferred minimum. All this output needs more energy input and for this you need a larger flow of gas and hence a larger gas pipe
