Quick background:
Living in a static round the back of house which is now fed from the outside tap at the front of the house. This tap will soon go when building works start out the front. I therefore need to add a new exterior pipe at the rear of the house and since there's no plumbing round the back, I am going to connect to the cold water pipe in the attic using a polypipe and then run this through the soffit down along outside wall to where the tap will be (external wall will have EWI, so should be safe from freezing). The tap will stay there longterm, so not a temp solution.
Question:
As I need sufficient pressure in the static caravan (25m from house) will 15mm pipe suffice? Or should I go for 22mm? I think the latter would be best, but increase the cost.
Thanks!
Quick background:
Question:
Thanks!
