PIR as Exit Detector
25 Feb 2013
London
Evening all!
Found my way here from a Google search and noticed that a lot of work has gone into this forum and you all seem like a friendly bunch!
My predicament:
I would like to use a single PIR as an exit detector for a maglocked door (i.e. I need the circuit to be NO, and NC on detection). The maglock controller software does not allow this to be reversed. Are there any standard (low cost) PIRs that provide this functionality? Would it be possible to wire this up using a standard relay of some kind? Any simple wiring hacks etc.?
Thanks,
Mike
you reallly need a request to exit pir take a look at this on ebay
260924797321 you can find the odd detector with a full relay no/nc but not many around these days
optex lx 40 have form c relay output
...or one of these on eBay
181080018481
They're really good!!
You could use a curtain pir to the side of the door and put a relay with it to give you the correct output. Try and use a transistorised relay to save the pir's output.
