PIR light in garden stopped working. Replaced lamp - no joy - though it had blown.
Checked voltage at light fitting - no volts.
My set up is , switch inside allowing permanent light if required, a sensor on wall in one position and light fitting on another point of wall - bought house with this set up.
Checked volts at inside switch and here's where it gets interesting 230v on both sides of switch. Checked switch all ok with ohms check.
My thought is problem with sensor - thus causing voltage at switched side of inside switch at all times.
Any thoughts on this from anyone would be greatly appreciated.
