Veritas alarm panel which seems to have been installed incorrectly.
The front door has no magnetic contact, a pir triggers the alarm.
So when they come in the alarm goes off after 3 seconds.
as I understand it a door contact is what is needed which would be set to entry exit and the pir to inhibit.
The door opening would start the entry and give 30 seconds or so to input code. Pir does not go off as inhibited.
Since no entry via a contact the pir triggers straight away even if set to inhibit
So my questions are do you set the pir as the entry exit?
Are pir generally wired to their own zone, or could several be wired to one zone, if so I guess all pirs would be disabled for the 30 seconds .
Adding a door contact would be best but unlikely to happen, so what's the best work around for this setup
Many thanks
Many thanks
