Hi
So I have the above system in new to me house, and have been trying to trace false alarm triggers. Voltmeter over the feed of the PIRs shows only 8 volts.
Have traced wiring back to junction box. Breaking the connections apart I get 13.6 volts from the controller feed. As soon as I wire any one of the PIRs in voltage drops to 10.5, and further when I add more PIRs. I understand that these can be sensitive to low voltage. Current draw is measured at 8-9ma.
What would cause this voltage drop? Current draw as above seems fine, and there's minimal resistance on the loop (about 1.5ohms)
Could it be my backup battery in the controller? Date on battery is 2013. Even on mains would I see a voltage drop when connecting things, or something else?
I have engineer code, manuals, and am comfortable programming it - it was factory reset when I bought the house so had to configure zones, wireless sensors etc.
